Adjusting Idle a bad idea for a newbie?
Posted: Sat Oct 29, 2005 3:11 pm
by Awox
Hello everyone, there aren't many people I can ask for help on these subjects all the time but as it is occasionally my motorcycle stalls when idle, sometimes it's a pain to compensate with the throttle especially while trying to send a SMS/text message on my phone.
Can I just set it to idle at a higher level so it behaves just like I was compensating with the throttle? Any advice? Cheers.
Oh, this doesn't happen often, but it's super-annoying when it does.
In other news.. I missed my first kangeroo this morning!
http://home.awox.net/blog/2005/10/30/do ... geroo.html
Posted: Sat Oct 29, 2005 6:09 pm
by Shiv
Well ah...while stopped at a red light (I'm assuming that's where you're idling as that's....pretty much one of the only places you would idle and mind if the engine died) you probably should be doing other things than texting a friend.
For instance, watching your mirrors to make sure the soccer mom at least sees you while she's texting her friend.
Posted: Sat Oct 29, 2005 9:03 pm
by flynrider
If you have a shop manual for your bike (whatever kind it might be), and a modicum of mechanical skills (can you change your oil and filter?), then setting the idle speed should not be too difficult. Most shop manuals will have a detailed explanation that should not be too hard to follow.
NOTE: If your bike has other problems, like poorly adjusted floats, timing, valves, etc... Bumping up the idle will probably not help very much.
Posted: Sun Oct 30, 2005 1:38 pm
by cb360
Yhay shouldn't be too tough. Just temember where it was before you changed it and if you start messing around with the carbs just change one thing at the time so you don't get all out of whack. And get the bike good and warmed up before you start.
Posted: Sun Oct 30, 2005 2:48 pm
by 9000white
text messaging on a motorcycle.
Posted: Sun Oct 30, 2005 7:02 pm
by Awox
WHILE STOPPED.
But thanks guys.
Yeah, of course not at lights. Heh.
