550 four
were trees
550 four
#1 Unread post by were trees »
75 550 four
the clutch basket makes noise.
theres to much end play inbetween the basket and the snap ring that hold s it on.honda doesnt make the thrust washers anymore that fix that.
can i have those made?or can i measure the shaft and get one somewhere else?or does another model work for this model?someone plese help? :frusty:
txbadboy
#2 Unread post by txbadboy »
my clutch basket makes noise too, but when i pull it in it goes away. im guessing this is the problem youre describing? im pretty sure thats just a common quirk in some of these old bikes. if you can find the component that causes it and its an easy fix, go for it. otherwise, im leavin mine just how it is. if it aint broke, dont fix it. :P good luck
1981 Honda CX500 Custom
$250 E-Bay resurrection in progress!
