What type of lubrication system
Posted: Mon Nov 07, 2005 7:26 am
by tewillia
Does a 2000 Yamaha R1 have a wet sump or a dry sump lubrication system?
Posted: Mon Nov 07, 2005 11:44 am
by niterider
The only bike that I believe with a dry pan is the Harley and even than I am not really sure of that. I know it has an oil tank.
Posted: Mon Nov 07, 2005 3:12 pm
by BuzZz
Wet-sump systems have no oil tank, as was mentioned. Harley's twins are the only modern bikes that spring to mind with this set-up. The R-1, and every other sportbike i can think of, use a wet-sump engine. If you add oil to the engine cases, it's probably a wet-sump. If you add oil to a separate tank, remotely mounted elsewhere on the bike, it's a dry-sump.
Posted: Mon Nov 07, 2005 3:13 pm
by ZooTech
And what about the Buells with the oil-filled swingarms? :laughing:
Posted: Tue Nov 08, 2005 9:43 am
by mydlyfkryzis
ZooTech wrote:And what about the Buells with the oil-filled swingarms? :laughing:
Dry Sump
Sump is bottom of engine. If the oil is not in the bottom of the engine, it is a dry sump.
Posted: Tue Nov 08, 2005 9:48 am
by ZooTech
Dry Sump
I know, I was just picking on BuzZz's statement.
Posted: Tue Nov 08, 2005 4:15 pm
by BuzZz
Buells ain't sportbikes, they're Hooligan bikes..... the best kind of bike. :mrgreen:
