HELP!!!!!!!!!!!!
HELP!!!!!!!!!!!!
Help!!! I lost my key to my 99 Yamaha r1 and my handle bars are locked. What should I do? Can I brake the ignition lock and get another one? Please help.
- Loonette
- Real Name: Kristin
- Years Riding: 13
- My Motorcycle: 2006/Kawasaki/Mean Streak/best bike ever
I would suggest calling your Yamaha dealership straight away and see what they can do for you. They may be able to obtain the "key code" by using the VIN# on the bike. Not sure how much that would cost, but I'd start with them first.
Cheers,
Loonette
Cheers,
Loonette
FIRST RESPONDERS DO IT WITH LIGHTS AND SIRENS!!
2006 Mean Streak 1600
- Wizzard
- Legendary 1000
Generally if you can dismantle your ignition you will find a set of numbers
that you can take to the stealership and have a key made from .
Regards, Wizzard
btw , if you bought the bike new you should have received 2 sets of keys . And in lieu of that if you did buy it new as Loonette said the stealership should have paper work with the key number .
Regards, Wizzard
