DAMN YAMAHAS!!!!
Posted: Wed Jan 04, 2006 6:15 pm
quick: am attempting to rebuild my 1986 Yamaha Maxim XJ700 front forks.
so - i keep running into problems. short list of parts purchased to alleviate these difficulties:
one set: 12, 14, & 17 mm hex sockets
one set: 1/2 socket extensions
one : 10" 1/2 socket extension
total: $40.
the factory specs manual from Yamaha tells me that I need the following two specific parts:
YM-01326 (22" T-handle 1/2")
YM-01365 (unknown size hex socket w/ connector @ 1/2")
so - b/c i ended up buying a 2", 4" and 10" extension set and didn't feel like going to Sears and buying a 20" 1/2 extension - i bought a second 10". fitted the 17mm socket head to it, made contact. could feel the top of the damper rod push in. turn. lots of free play. shine flashlight down it. compare the visualized size to the cap bolt. estimate 1-2 mm bigger (damper rod head, that is) than cap bolt (which is a 17mm hex fitting).
start looking on line for a 19mm hex socket. can't find a damn one. start combing through yamaha's "official" sites. start making calls to yamaha. no one knows what the hell i'm talking about.
"19 mm hex socket? what are you working on? a flying pig?"
so i have attempted to circumvent the wall. attempted to climb the wall. now - i'm just beating my head against the wall called the Yamaha Maxim XJ700 damper rod (23" inside the fork tube).
Has anyone got some help they could lend? Thanks very much.
total: $40.
