Yahoo!
Posted: Wed Jan 11, 2006 12:51 pm
by Gnarlyroad
:D Got my electrical problem fixed. A new main fuse in and it turns over just fine thank you. Now onto new air filter, oil and filter change, new valve cover gaskets, final drive grease and bearing check, brake check(front and rear).
Have a ? re: fuel petcock. At present it leaks when in fuel position(I ussually leave it on reserve for this reason) and I was wondering if it could just be the o-ring needs changing. Iam hoping this could be the simple solution. Anyone fixed a leaking fuel petcock before.
Posted: Wed Jan 11, 2006 7:17 pm
by TechTMW
It might be a prob w/ the o-ring... Check on parts availability ... sometimes you just have to buy a new petcock because the rebuild kit's not available.
Posted: Thu Jan 12, 2006 11:17 am
by 9000white
if you will tell us what it is someone might know if a repair kit is available for it.
yahoo
Posted: Thu Jan 12, 2006 1:35 pm
by Gnarlyroad
It's an 83 cb650 nighthawk. Has 50,000 klicks on it and is still running fine. Well okay some cam chain noise but I'm not enough of a mechanic to fix that :oops: and the bike shop wants more than the bike is worth to fix it.
