Motorcycle Tools
gr8ful rydr
Motorcycle Tools
#1 Unread post by gr8ful rydr »
Just got a bike and want to learn to do as much of the maintenance as possible on my own. I don't currently own much in the way of tools. I was thinking of going down to Sears and picking up one of their combo packages. I'd really like to build something complete over time. I own a Yamaha V-Star 1100 if that is important. Any suggestions on what I should get?
bennettoid
#2 Unread post by bennettoid »
Screw driver always comes in handy.
And a hammer, don't forget a hammer.
'94 vulcan 750
TechTMW
#3 Unread post by TechTMW »
A typical $200 craftsman setup should have most of what you need.
Some definite things to add to that -
Feeler gauges
3/8" drive beam or click-type Torque wrench
An Electronic Multimeter (Digital is better)
Usually the craftsman packages have crappy screwdrivers (like the kind w/ an aluminum shaft and magnetic tips) so you might want to get a complete screwdriver set too.
Other things that may not be in the set (or be necessary) but will make your life easier -
Breaker Bars (3/8 & 1/2 drive)
U joints
Ratcheting wrenches
(3/8 & 1/4) T-Handle
3/8" Impact Driver
Everything else you'll figure out as you go along. You'll probably need a torx set for a newer bike and a few sockets athat are bigger than the ones in your set (like maybe a 21mm or something like that)
Uncle_Bob
#4 Unread post by Uncle_Bob »
I strongly suggest click type, it may not be as reliable, but beam types is almost usless for me, when I was fixing my Mitsubishi Eclipse engine I couldnt even see the dial due to space restrections and the angle at which I was looking at it.
Almost forgot to add, never overtighten aluminum parts VERY easy to crack them dont ask.
Uncle Bob Touched me!
CNF2002
#5 Unread post by CNF2002 »
All you need is wd40 and duct tape. If it moves and it shouldnt, use the duct tape. If it doesnt move and it should, use the wd40.
In all seriousness if you are going to do alot of electrical work, get a multimeter and a wire tester (they look like a pen and when you touch a wire, it'll light up if its hot); they're cheap.
Other than that get a good socket/wrench set, with both regular and deep sockets if you can. Get a screwdriver set with an extension, and a screwdriver 'wrench' (works like a socket wrench but standard screw bit goes into it).
2002 Buell Blast 500 /¦\
Keyoke
Years Riding: 22
#6 Unread post by Keyoke »
Digital Tyre Pressure guage - cheap, yet priceless!!
Don't give up.
Skier
#7 Unread post by Skier »
TechBMW wrote:A typical $200 craftsman setup should have most of what you need.
Feeler gauges
This is most of the tools I use for wrenching on my bike. I've added a few things here and there but the vast majority of the tools were included in the Craftsman kit.
ZooTech
Years Riding: 18
#8 Unread post by ZooTech »
You've got a Yamaha, so be sure to get everything in Metric (don't forget the Allen wrenches!). Be sure to get a set of larger sockets (my axle bolts are 27mm, not included with most socket sets). Also pick up a bike lift and a battery tender.
paul246
#9 Unread post by paul246 »
The very first tool you should buy is located at your Yamaha dealer. If you are serious about doing any real work on your bike you should bite the bullet and buy the factory shop manual for your particular bike. Guaranteed, this will be the best tool investment you can possibly make.
Just by perusing through the manual in your armchair you will gain more knowledge of what size sockets you will require, where things are located, maintenance schedules, fastener torque values, not to mention the proper sequence to take during a disassembly or reassembly.
I think I paid around $70.00CDN for my wife's 650 V-Star manual and it paid for itself in short order. BTW, I have the factory shop manuals for every bike I own.
Honda XR650L Dual-Sport
#10 Unread post by dr_bar »
A good starting point can be as simple as taking the stock tool kit and replacing everything in it with good quality tools. Then as paul246 said, grab that shop manual. Open it up and look for any of the specialty tools that may become necessary.
