Chopper frame terms, help please
Posted: Tue Jan 17, 2006 10:11 am
by KeithB
I am looking at chopper frames. Can someone here explain the following terms they use?"
stretch
downtubes
backbone
soft tail means it has rear suspension right?
Thanks
Posted: Tue Jan 17, 2006 11:44 am
by rhost
stretch is how much longer the frame is in length
downtubes are the tube or tubes going from the neck of the bike under the motor and connecting with the backbone
backbone is the tube going from the neck over the motor and connecting with the downtubes
yes soft tail means that it has a suspention.
Posted: Tue Jan 17, 2006 12:53 pm
by KeithB
thanks
i found a decent deff of strech in the TMW diectionary
Stretch - A chopper term for increasing the neck rake of a motorcycle by extending the length of the frame's front downtubes, which is that part of the frame between the neck and the front motor mounts. Stretching is a chopper modification dating from the 1960's. Its effect was to raise the fork neck, increasing the degree of rake, and allow for the use of a long, extended fork without significantly raising the engine and drivetrain (and bike's center-of-gravity) high into the air. The bike retained a low, long look, high in the center, front to back, and handled relatively well
Posted: Tue Jan 17, 2006 6:13 pm
by BuzZz
KeithB wrote: .............. The bike retained a low, long look, high in the center, front to back, and handled relatively well
*relatively* is a relative term......
