Page 1 of 2
Dropping a bike
Posted: Thu Feb 16, 2006 9:26 am
by SuperRookie
Nooo not like that
I know that it's possible to lower a bike for a shorter rider. How far is too far when lowering so as not to drastically affect handling/steering characteristics? One inch? Two inches? The bike in question is an EX500.
Posted: Thu Feb 16, 2006 10:16 am
by Jamers!
im sure its possible. With smaller tires and smaller forks i think you can lower a bike. I dont know how low is too low though
JWF
Posted: Thu Feb 16, 2006 1:00 pm
by Sev
Smartest way to do it is to cut down the seat.
Otherwise some aftermarket rear shocks will allow you to drop the back end a little. There's other things you can do, but realiztically even a small change in height will affect the bikes handling, you're better off messing with the seat.
Posted: Thu Feb 16, 2006 2:29 pm
by High_Side
There are aftermarket links for the rear suspension on many bikes to help you lower it. You can also drop the forks in the triple clamps on the front. You have to pay attention to clearances when you d o this however. My wifes Monster has been lowered and it handles just fine.
Posted: Thu Feb 16, 2006 2:39 pm
by DivideOverflow
just wear taller boots! j/k
I would start with the seat too. Ive heard of people getting EX500's lowered two inches by getting the seat done.
You can lower the preload by 1.5" too. But I would be more inclined to just shave 2inches off the seat. (probably would have an upholstery shop to this).
Posted: Thu Feb 16, 2006 2:58 pm
by SuperRookie
High_Side wrote:There are aftermarket links for the rear suspension on many bikes to help you lower it. You can also drop the forks in the triple clamps on the front. You have to pay attention to clearances when you d o this however. My wifes Monster has been lowered and it handles just fine.
Right, the Uni-trak tie rods ("dogbones"?) I'm thinking a combination of shaving the seat, lowering the rear and adjusting the forks will work. Maybe start with the seat...and adjust everything else as nec. I know you don't want to drop the forks too much so bottoming out doesn't become a possibility...
Oh..and won't shaving the seat down make it uncomfortable? Anyone done this? Any input?
PS: Just for clarification...it's not for me...I can flatfoot my 500 just fine thanks
Posted: Thu Feb 16, 2006 3:33 pm
by High_Side
SuperRookie wrote:Right, the Uni-trak tie rods ("dogbones"?) :
Different bikes require different parts. Google it.
Yes. I even considered putting a monster 620 seat on the S2R because it uses the same pan and far less foam. After sitting on one however I changed my mind. More seat foam is a good thing.
Posted: Thu Feb 16, 2006 6:33 pm
by SuperRookie
DivideOverflow wrote:just wear taller boots! j/k
Yeah...some platform boots oughta do
Two inches off the seat...whew...definitely need an "iron butt" for that
Adjusting the pre-load...hmmm there's an idea
Posted: Fri Feb 17, 2006 6:42 am
by Sev
Adjusting the preload adjusts how it handles more then the height.
Posted: Fri Feb 17, 2006 11:31 am
by SuperRookie
Hmmm..so adusting the pre-load won't affect how much the bike squats when it's sat on?
