How to free seized cylinder?
Posted: Thu Feb 16, 2006 4:12 pm
by Bax
I'm playing around with an old Honda C200 engine and found that the cylinder is seized. Really, really seized!
Any ideas on how to free it?
Already tried: Block of wood and hammer.
(After soaking for 2 days with WD-40)
Result: Cylinder is laughing at me and my thumb is sore. :frusty:
Bax
Re: How to free seized cylinder?
Posted: Thu Feb 16, 2006 4:17 pm
by Bax
The FrankenBike.
Ugly Fu**er, ain't she? :D
Bax
Bax wrote:I'm playing around with an old Honda C200 engine and found that the cylinder is seized. Really, really seized!
Bax
Posted: Thu Feb 16, 2006 4:24 pm
by ZooTech
Try a penetrating oil. WD40 is formulated to displace water (hence the name). You'll probably have to tear the motor down.
Posted: Thu Feb 16, 2006 4:27 pm
by 9000white
pour the cylinder full of diesel fuel and let it sit for a week.if it dont free up then forget it.
Posted: Thu Feb 16, 2006 4:30 pm
by Bax
Have you heard of a product called MetalClean or CleanMetal. Someone suggested I try it but I never heard of it and am having trouble finding it.
As for tearing the engine down, that's what I was in the process of doing when I ran into the seized piston/cylinder.
Unfortunately, the head bolts are also seized so I can't separate the engine to attack from the other side. It never rains but it pours.
Thanks for responding. :)
Bax
Posted: Fri Feb 17, 2006 12:42 am
by mustangski
The best thing that I found is a product called Marvel mystery oil. It works great, I used it to free up the cylinders on an old 302 I had a couple of years back. Just pour some in the cylinder, let it soak overnight and then break out the hammer and wood again. Good luck.
Posted: Wed Mar 01, 2006 6:47 pm
by JoeyMac
Marvel works good, brake fluid is probably the best though. Good luck!
