Chain Adjustment
Posted: Thu Mar 16, 2006 12:18 pm
by eugeart
I noticed some real slack in my chain (several inches) after I replaced my tires. I adjusted the tension so there was about an inch or maybe a little more of play (bottom part). Is this too tight?
Posted: Thu Mar 16, 2006 1:26 pm
by niterider
That is close to right, but I think that may be a little bit loose yet. Let's see if we get other views on the subject.
Posted: Thu Mar 16, 2006 1:44 pm
by ejshotgun
I adjust mine a tad under an inch.
But the best thing to do is get the manual.
Posted: Thu Mar 16, 2006 3:15 pm
by flynrider
Your owners manual will be the final authority. It'll give you a range of play. My experience is that keeping a chain at the looser end of the scale will make a dramatic difference in how long the chain and sprockets will last. I used to adjust towards the tighter end of the scale and my chain was needing adjustment and replacement much more often.
On my current bike, I've been leaving it at the loose end of the scale and I'm going much longer between adjustments. The current chain has 14K miles on it and I've only had to adjust it twice. It still has a long way to go before it's worn out.
Posted: Thu Mar 16, 2006 3:27 pm
by eugeart
EXACTLY! I figure that too tight can lead to problems- worn sprockets and even busted links (chain failure).
I don't think having it slapping around is too good either: imagine one's chain jumping off the sprocket and its' landing between the sprocket and wheel leading to a catostrophic rear wheel lock-up on the Hwy! Ouch.
Unfortunately, my "used" Katana came without a manual. Maybe some of you Kat owners out there might know?
