carb balancing
Posted: Fri Mar 17, 2006 12:17 pm
by were trees
on carb balancing
the tubes you had a picture of in the carb balancing topic
i have a 75 honda cb and it has the 5mm holes on the intakes
does any one have a suggestion on how to get the tubes adapted to my holes.they have little adapters that motion pro makes but is there a ghetto version. any good ideas?
Posted: Fri Mar 17, 2006 2:02 pm
by 9000white
if you have the patience to do it you can get some 5mm bolts and cut the heads off them and drill a hole in them --put a nut with a small o ring behind it then screw them in and tighten the nut up to make a seal.dont tighten nut up so tight that it splits o ring.
Posted: Sat Mar 18, 2006 11:22 am
by Skier
Is your problem you can't get the tubes over an existing nipple since it's too big, or do you have a 5mm threaded hole you need to get something in to?
If it's the former, try heating the tubing in hot water, then pushing it down over the sharp end of a pencil. It'll stretch and hopefully not break, letting you put it over the big nipple.
If it's the latter, 9000white's instructions sound like an inexpensive way to take care of it.
