Alright, what the heck is an apex?
Shiv
#1 Unread post by Shiv »
It's the invisible line you follow through a curve isn't it? That's the definition I've gathered from various contexts.
If so, what is an early apex? Late apex?
Have fun on the open /¦\
www.totalmotorcycle.com
I know, I was surprised too.
#2 Unread post by Sev »
The easiest way to explain it is to imagine a ball thrown upwards. Not straight up mind you. It follows a smooth curve if you were to track it's path. The Apex is the very top point.
In a turn it's the same idea, the highest part, or the furthest point from the start.
I think....
VermilionX
#3 Unread post by VermilionX »
from what i understand...
using a delayed apex in a corner leaves you w/ more room to adjust midway in the corner (in case of road hazards) and have a better exit line. therefore, you're able to accelerate earlier and be faster in the corner.
Dragonhawk
#4 Unread post by Dragonhawk »
This explains it:
http://www.turnfast.com/tech_driving/dr ... ring.shtml
Here is an illustration to show it:
[b]Are you a beginner rider?
SuperRookie
Real Name: Daryl
My Motorcycle: 2004 Ducati 620ie
#5 Unread post by SuperRookie »
As we can see, the apex is the mid-point of the corner. Of course, this illustration doesn't necessarily represent the best cornering line approach for bikes. As VX touched on, and according to my own reading, the 'delayed apex' is the technique to use. You 'turn in' later, see farther through the corner as a result, and have much less probability of exiting wide.
"Not just your 'ordinary' Rookie..."
Ninja Geoff
Real Name: Geoff
#6 Unread post by Ninja Geoff »
delayed apex is the safe way on the street.
The illustration shows the fastest possible line for anything that would take that corner. THOUGH depending on the NEXT turn after that, you'll tweak the line so you can get a decently fast line through both/all turns.
