Suzuki GS500E revs high, loses power in fourth gear, bkfires
Posted: Fri Mar 24, 2006 2:04 pm
Hi all...
I'm new here, and relatively new to the world of motorcycles. Just got my license in October, and have been taking advantage of every reasonably warm (35 degrees and above) day to get the bike out and ride her around.
It was running rough, then got to the point where it lost power in the higher gears. One day it just started doing that, and when I turned for home, it kept losing more power, gaining and losing, then stopped. I pushed the bike for awhile, then started it again, ran it for about one minute, then it stopped again. I did this three or four times until I got home.
Had it into the shop and they did a complete maintenance check, and it ran smooth for the past two weeks. Now it's doing that again, along with plenty of backfiring, and I have to keep the idle rpms above 2000 so that it won't stall out. Also, when it runs, it surges quite a bit, and I have to hang on well to the bike so that it doesn't shoot out from under me when it surges up.
The mechanic has diaphragms on order, still waiting for them to come in, but does anyone know why it does this?
This is a 1997 model. It's a great bike, but this particular episode is causing me some grief, because I really want to use it daily.
Thanks for any help you can give me!
