For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... enture.htm
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2015/2015-KTM-1290-Super-Adventure1-small.jpg)
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2015/2015-KTM-1290-Super-Adventure4-small.jpg)
2015 KTM 1290 Super Adventure on http://www.totalmotorcycle.com
THE NEW BENCHMARK IN THE TRAVEL ENDURO SEGMENT...
The 1290 KTM Super Adventure sets a new benchmark in the travel enduro segment with a class-leading equipment specification that leaves other travel enduros playing catch-up. The Super Adventure’s uncompromisingly powerful KTM engine is matched by safety and electronics packages that are streets ahead of the competition, which means that sports riding meshes seamlessly with a versatile travel enduro style, making the Super Adventure the perfect ride for any journey.
2015 KTM 1290 Super Adventure http://www.Totalmotorcycle.com Key Features
» Fully equipped
» Exceptionally comfortable
» Uncompromisingly powerful
» Unrivalled safety
» 100% KTM
SUPER EQUIPPED
» WP Semi-active Suspension
» C-ABS (Lean angle sensitive with MSC)
» MTC (Motorcycle Traction Control)
» TPMS (Tyre Pressure Monitoring System)
» Multi-function cockpit
» Full set of modes (Ride-by-Wire, MTC, ABS, Damping)
» Cruise control
» 30 litre long range fuel tank
» LED cornering lights
» Daytime running light
» LED indicators
» Adjustable ergonomics
» Easy adjustable windshield height
» Heated grips
» Heated comfort seats
» Ultra-rugged offroad spoked wheels
» Immobiliser
» Aluminium handlebar, black coated and tapered
» Luggage rack and case carriers
» Servo fan
» Handguards
» Steel crash bars
» Side and centre stand
2015 KTM 1290 Super Adventure - http://www.Totalmotorcycle.com USA Specifications/Technical Details
MSRP Price: $ See dealer for pricing in USD
ENGINE
Design 2-cylinder, 4-stroke, spark-ignition engine, 75° V arrangement, liquid-cooled
Displacement 1,301 cm³
Bore 108 mm
Stroke 71 mm
Starting aid Electric starter
Performance 118 kW (160 hp)
Engine lubrication Forced oil lubrication with 3 rotor pumps
Primary gear ratio 40:76
Secondary gear ratio 17:42
Cooling system Liquid cooling system, continuous circulation of cooling liquid with water pump
Clutch PASC™ anti-hopping clutch/ hydraulically operated
Ignition system Contactless, controlled, fully electronic ignition system with digital ignition timing adjustment
CHASSIS
Frame Tubular space frame made from chrome molybdenum steel, powder-coated
Fork WP Semi-active Suspension USD Ø 48 mm
Shock absorber WP Semi-active Suspension PDS Monoshock
Suspension travel front 200 mm
Suspension travel rear 200 mm
Brake system front Twin-disc brake with radially mounted four-piston brake calipers
Brake system rear Single-disc brake with two-piston brake caliper; fixed brake disc
Brake discs - diameter front 320 mm
Brake discs - diameter rear 267 mm
Chain 5/8 x 5/16" X Ring
Steering head angle 64°
Wheel base 1,560±15 mm
Ground clearance (unloaded) 220 mm
Seat height (unloaded) 860/875 mm
Total fuel tank capacity approx. 30 l
Unleaded premium fuel (95 RON)
Weight without fuel approx. 229 kg
