2015 Honda Interceptor VFR800F - Coolness Factor = 69.0%
- Years Riding: 32
2015 Honda Interceptor VFR800F on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... FR800F.htm
Refinement No Other Bike Can Touch...
With experience comes wisdom. Sure, fluorescent-colored breakfast cereal might be fun when you’re a kid, but as you learn more, you start eating smarter. Same with your motorcycles. Loud, flashy bikes that try to grab your attention with outrageous styling, but do not turn or stop well? Seating positions that would give a chiropractor nightmares? Pass. The experienced rider looks for a machine that works with him or her. That offers plenty of performance, that’s comfortable to ride—even at a brisk pace.
For generations, that’s meant Honda’s Interceptor, a bike that performs as well in the curves as it does on the open road. The Interceptor's 782cc V-4 VTEC engine with fuel-injection mapping for better low-end torque feel. It includes adjustable seat height to better fit a range of riders, front-mount radiator for a slimmer profile, radial-mount front brakes, and all-side muffler, wheels and Pro-Arm swingarm. There’s even a Deluxe model for 2015 with features like traction control, anti-lock brakes, self-cancelling turn signals, a centerstand and heated grips.
A Showcase Of Our Best Technology
The Interceptor is a groundbreaking machine and always has been. The latest 2015 version offers a stunning number of features like LED headlights, available traction control and our Anti-Lock Braking System (ABS). And the V-4 VTEC engine runs on two valves per cylinder at low engine speeds and four valves per cylinder at higher revs. All are designed to give you one of the most capable machines we’ve ever built.
2015 Honda Interceptor VFR800F - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $12499 USD
Canada MSRP Price: $14499 USD
ENGINE
Engine Type
782cc liquid-cooled 90° V-4
Bore And Stroke
72mm x 48mm
Induction
PGM-FI with automatic enrichment circuit, 36mm throttle bodies
Ignition
Computer-controlled digital with three-dimensional mapping and electronic advance
Compression Ratio
11.8:1
Valve Train
VTEC DOHC; four valves per cylinder
DRIVE TRAIN
Transmission
Close-ratio six-speed
Final Drive
#525 O-ring chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension
43mm with spring-preload adjustability; 4.3 inches travel
Rear Suspension
Pro Arm single-side swingarm with Pro-Link® single spring-preload and rebound damping adjustability; 4.7 inches travel
Front Brake
Dual full-floating 310 mm discs with four-piston calipers
Rear Brake
Single 256 mm disc
Front Tire
120/70ZR-17 radial
Rear Tire
180/55ZR-17 radial
DIMENSIONS
Rake
25.5°
Trail
95mm (3.74 inches)
Wheelbase
57.4 inches
Seat Height
31.0 inches to 31.8 inches
Curb Weight
529 pounds (Includes all standard equipment, required fluids and a full tank of fuel-ready to ride)
Fuel Capacity
5.2 gallons
ENGINE
Engine Type
Bore And Stroke
72mm x 48mm
Induction
Ignition
Compression Ratio
11.8:1
Valve Train
DRIVE TRAIN
Transmission
Final Drive
#525 O-ring chain
Front Suspension
Rear Suspension
Front Brake
Rear Brake
Single 256 mm disc
Front Tire
120/70ZR-17 radial
Rear Tire
180/55ZR-17 radial
DIMENSIONS
Rake
25.5°
Trail
95mm (3.74 inches)
Wheelbase
57.4 inches
Seat Height
Curb Weight
Fuel Capacity
5.2 gallons
2023 Motorcycle Model Guides
- Years Riding: 32
Re: This Week: 2015 Honda Interceptor VFR800F - Vote Now
As requested this week...a good ol' Honda bike!
Enjoy!
Enjoy!
- ceemes
- Real Name: a big secret
- Years Riding: 26
Gave it a solid cool. Been a big fan of the Interceptor ever since I started riding in the early 80's and it was THE bike to have at the time. Later when I returned to riding, it was on a Honda V45 Sabre, basically the same engine though not quite as was in those early Interceptors.
I will have to sit on one these new ones to see if it is the sport bike for those of us that don't bend over as well as will did neigh on 35 years ago.
It looks good in white.
- faded sun
- Real Name: John, but my friends call me Jock
- Years Riding: 46
- My Motorcycle: 2012 Victory Vision Tour/Honda Stateline
If you drive fast enough the wind helps hold you up when you are bent over.ceemes wrote:Gave it a solid cool. Been a big fan of the Interceptor ever since I started riding in the early 80's and it was THE bike to have at the time. Later when I returned to riding, it was on a Honda V45 Sabre, basically the same engine though not quite as was in those early Interceptors.
Jock
- Site Supporter - Silver
- Real Name: Pete
- Years Riding: 10
the back still hurts with the extension.
- ceemes
- Years Riding: 26
faded sun wrote:If you drive fast enough the wind helps hold you up when you are bent over.ceemes wrote:Gave it a solid cool. Been a big fan of the Interceptor ever since I started riding in the early 80's and it was THE bike to have at the time. Later when I returned to riding, it was on a Honda V45 Sabre, basically the same engine though not quite as was in those early Interceptors.
Holding oneself up is not the issue, folding oneself into the correct riding position is.........me auxiliary spare tyre has a habit of getting in the way......
- Veteran
- Real Name: Art
- Years Riding: 50
- My Motorcycle: FXDBI
I've always liked this bike over the years and like creemes I rode the v45 many years ago. I very much like the engine. It's smooth, strong and potent.
- HYPERR
- Legendary 3000
Altho nowhere as pretty as the '97 VFR750F nor awesome as the gear driven quad cammed non-VTEC '98 VFR800FI; all VFRs that aren't the 1300 are awesome in my book.
- Grey Thumper
- Legendary 1000
- Real Name: Dino
- Years Riding: 9
Whatever happened to mid-size sport tourers? Now only this VFR and BMW's F800GT come to mind (and both are evolutions of older platforms).
Comfortable ergos, some wind protection, some hard panniers, less weight, more nimbleness; isn't this all the touring rider needs? (Well, touring riders that don't carry pillions). Anyway, it's a solid cool, particularly in white.
