For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... BR650F.htm
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2015/2015-Honda-CBR650F2-small.jpg)
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2015/2015-Honda-CBR650F1-small.jpg)
About Limits...
Bikes used to be arranged around how big their engines were: 250, 500, 750 or 1000cc. Then inflation set in, and 500s became 600s, and the 750s became 800s. Unless you were racing in a special displacement grouping, it all seemed a little silly. Didn’t we all just want a great motorcycle, regardless of some arbitrary engine size?
Well, that’s what you get with the CBR650F, and why riders find is such a joy. A truly fun ride at a great price, it's both practical and fun—what Honda does like no one else. Its inline-four engine specifically tuned for low-to-midrange torque, delivering a powerband that’s suited for a wide range of riding styles. Weekday commuter, weekend sport riding, long trips, short hauls, solo or with a passenger—the CBR650F does it all.
CBR650F - built for both the young and the young at heart
Who says that practical, comfortable, everyday bikes can’t generate the adrenalin rush of their RR brethren? Case in point, the CBR650F - its high torque, in-line four-cylinder engine, tuned for strong low-end, mid-range and top-end power, provides tremendous drive off the line and out of turns. The all-new steel chassis positions the engine far forward for optimal weight distribution and is tuned to provide an excellent balance between comfort and rigidity. An aluminum swingarm with a direct mounted single-shock handles the suspension duties at the rear while a 41 mm front fork keeps the front end planted in turns. Powerful, dual 320 mm wave-style front-brake rotors, supported by a single 240 mm rear, provide track level stopping power. Two channel ABS works in harmony with the wide, high-traction sporting radial tires to help ensure strong and secure stopping in a variety of conditions.
So the CBR650F has the sporting credentials to live-up to the CBR designation, but what will catch your eye first is the unique styling. The design team for the CBR650F included a number of young engineers in their 20s who wanted to create a thoroughly modern and unique sport bike for today’s world. Since the engine, chassis, bodywork and, even, the wheels were all new, they had virtually a blank canvas to work with and what they came up with is a stunning design. From the minimalist full fairing that leaves most of the engine exposed, to the sweeping exhaust headers, to the arcing aluminum swingarm, the CBR650F is attractive from any angle.
2015 Honda CBR650F - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $8499 USD
Canada MSRP Price: $9499 CDN
ENGINE
Engine Type
649cc Liquid-Cooled Inline Four-Cylinder
Bore And Stroke
67mm x 46mm
Induction
PGM-FI Programmed Automatic Enrichment Circuit, with 42mm Throttle Bodies
Ignition
Digital transistorized with electronic advance
Compression Ratio
11.4:1
Valve Train
DOHC; four valves per cylinder
DRIVE TRAIN
Transmission
Six-speed
Final Drive
#525 O-ring chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension
41mm Fork; 4.3 inches travel
Rear Suspension
Single shock with spring-preload adjustability; 5.0 inches travel
Front Brake
Two-piston calipers with dual 320mm discs
Rear Brake
Single-caliper 240mm disc
Front Tire
120/70ZR-17 radial
Rear Tire
180/55ZR-17 radial
DIMENSIONS
Rake
25.3° (Caster Angle)
Trail
101.3mm (3.98 inches)
Wheelbase
57 inches
Seat Height
31.9 inches
Curb Weight
461 pounds (Includes all standard equipment, required fluids and a full tank of fuel—ready to ride)
Fuel Capacity
4.5 gallons
Miles Per Gallon
TBD*
OTHER
Model Id
CBR650F
Emissions
Meets current EPA standards. California version meets current CARB standards and may differ slightly due to emissions equipment.
Available Colors
Red, Candy Blue, Matte Black Metallic
