For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... 25-Pro.htm
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2017/2017-Kawasaki-Z125-Pro2-small.jpg)
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2017/2017-Kawasaki-Z125-Pro4-small.jpg)
Kawasaki’s Most Nimble Bike...
The 2017 Kawasaki Z125 PRO is the bike to conquer the city, regardless of your riding experience or how much gas money you have in your pocket. Built with an emphasis on fun, the Z125 PRO is designed to amplify the thrill of riding.
The Z125 PRO is a visually striking motorcycle with styling that’s a little on the dark side. It not only has edgy looks, but it's also a blast to ride. It fits into that perfect package for those desiring a small, pressure-free motorcycle with plenty of capabilities, low price and great gas mileage. Ideal for someone looking for a real motorcycle, but without the high pressure and costs associated with a larger bike. Thanks to the performance-oriented suspension, easy maneuverability and high fun level, it’s also a motorcycle you won’t soon outgrow. The Z125 PRO was built for the pureness of the riding experience.
Small in size. Big on fun. The all-new Kawasaki Z125 PRO is a nimble streetfigher that’s designed to defy what a lightweight motorcycle can be. With radical Kawasaki “Z” styling, the Z125 PRO is your invitation to the rebellious side of fun.
2017 Kawasaki Z125 Pro http://www.Totalmotorcycle.com Key Features
•Compact size and light weight (224.8 lbs wet) makes for easy maneuverability
•Large 2-gallon tank
•Low seat height (30.7 inches)
•Performance suspension suitable for comfortable and sporty riding
•Capable for two-up riding
2017 Kawasaki Z125 Pro - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $2999 USD
Engine: 4-stroke, 1 cylinder, SOHC, 2-valve, air-cooled
Displacement: 125cc
Bore x stroke: 56.0 x 50.6mm
Compression ratio: 9.8:1
Fuel system: DFI® with 24mm throttle body
Ignition: TCBI with electronic advance
Transmission: 4-speed, return shift
Final drive: Sealed chain
Rake / trail: 26.0 degrees / 2.7 in.
Front tire: 100/90-12
Rear tire: 120/70-12
Wheelbase: 46.3 in.
Front suspension / wheel travel: Inverted telescopic fork/3.9 in
Rear suspension / wheel travel: Swingarm, single shock/4.1 in
Front brakes: Single 200mm petal-style disc
Rear brakes: Single 184mm petal-style disc
Overall length: 66.9 in
Overall width: 29.5 in.
Overall height: 39.6 in.
Seat height: 31.7 in.
Curb weight: 224.8 lbs.
Fuel capacity: 2.0 gal.
Color choices: Candy Lime Green
Metallic Graphite Gray
MSRP: $2,999
Limited Warranty: 12 Months
Kawasaki Protection Plus: 12, 24, 36 or 48 months
