For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... -Ultra.htm
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2017/2017-Harley-Davidson-Tri-Glide-Ultra2-small.jpg)
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2017/2017-Harley-Davidson-Tri-Glide-Ultra3-small.jpg)
2017 Harley-Davidson Tri Glide Ultra on www.Totalmotorcycle.com
How much motorcycle can you fit on three wheels? One look at the Tri Glide® Ultra motorcycle and you'll have your answer...
Make your 2017 Tri Glide® Ultra a one of a kind. There’s more than an added wheel at work here.
The Tri Glide® Ultra is everything you love about the Ultra Limited, only on three wheels. You get every feature and improvement starting with the power of the all-new Twin-Cooled™ Milwaukee-Eight™ 107 engine. Other touring features include a 4-speaker, premium BOOM!™ Box 6.5 GT infotainment system with GPS and color touchscreen, electronic cruise control and 6.8 cubic feet of storage space. Get into the middle of nowhere on this one and you won’t be coming back anytime soon.
The Tri Glide® Ultra model gives two-wheel touring enthusiasts a three-wheel alternative with the performance, excitement, and style that’s pure Harley-Davidson. Built from the frame up to provide maximum comfort and handling on every ride, it’s equipped with a win-Cooled™ Milwaukee-Eight™ 107 engine. It also includes electric reverse to put complete control at the rider’s fingertips.
Trike
The Harley-Davidson® Trike platform brings original-equipment design, quality and service to the three-wheel motorcycle segment. Trike model utilizes a frame and associated chassis structure and geometry engineered specifically to handle the loads generated by the steering forces and weight of a three-wheel vehicle.
2017 Harley-Davidson Tri Glide Ultra www.Totalmotorcycle.com Key Features
NEW IN 2017
Twin-Cooled™ Milwaukee-Eight™ 107 engine, the most powerful, coolest-running motor we’ve ever built
Rear exhaust pipe and catalytic converters repositioned away from the passenger for less heat and a more comfortable ride
Precision water-cooling for cooler running and consistent performance
Improved fuel economy to give you more out of every tank of gas
Paint color options including Custom color
2017 Harley-Davidson Tri Glide Ultra - www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $34339 to $36,089 USD
Canada MSRP Price: $41799 to $43799 CDN
Europe/UK MSRP Price: £29395 to £30435 GBP (On The Road inc 20% Vat)
PRICING 6
Vivid Black $34,339
Color Option $35,189
Two-Tone Option $35,689
Custom Color Option $36,089
Security Option Standard
Premium Radio Option Standard
California Emissions $200
Freight $856
DIMENSIONS
Length 105.1 in.
Seat Height, Laden 7 27.1 in.
Seat Height, Unladen 7 28.3 in.
Ground Clearance 4.5 in.
Rake (steering head) (deg) 26
Trail 3.94 in.
Wheelbase 65.7 in.
Tires, Front Specification MT90B16 72H
Tires, Rear Specification P205/65R15
Fuel Capacity 6 gal.
Oil Capacity (w/filter) 5 qt.
Weight, As Shipped 1,195 lb.
Weight, In Running Order 1,230 lb.
Luggage Capacity -Volume 6.8 cu ft
INFOTAINMENT
Size 6.5 inch
Type Color
Watts Per Channel 25.0
Speakers 4.0
Speaker Size 5.25 inch/6.5 inch - P&A Upgrade
Headset Specifications (if equipped) 16-64 ohms
AM Standard
FM Standard
Weather Band (WB) Standard
SD Card, Flash Drive and MP3 - via USB Connection Supported
Languages English (US/UK), German, Spanish (Mexico/Spain), French (Canada/France), Italian, European Portuguese
Hands-free Mobile Phone - via Bluetooth Standard
Voice Recognition Languages: Phone functions only English (US/UK), German, Spanish (Mexico/Spain), French (Canada/France), Italian, European Portuguese
Rider/Passenger Intercom Standard
"Vehicle Information Screen (Air temperature, oil pressure and engine temperature)" Standard
Text-to-Speech (TTS) Languages English (US/UK), German, Spanish (Mexico/Spain), French (Canada/France), Italian, European Portuguese
USB USB/MTP/iPod/iPhone
Bluetooth Phone/Media Supported
SiriusXM Presets 20 - P&A Upgrade (USA & Canada only)
Voice Recognition Languages: Tuner/Media/Navigation English (US/UK), German, Spanish (Mexico/Spain), French (Canada/France), Italian, European Portuguese
ENGINE
Engine 1 Twin-Cooled™ Milwaukee-Eight™ 107
Bore 3.937 in.
Stroke 4.374 in.
Displacement 107 cu in
Compression Ratio 10:01
Fuel System 3 Electronic Sequential Port Fuel Injection (ESPFI)
DRIVETRAIN
Primary Drive Chain, 34/46 ratio
Gear Ratios (overall) 1st 10.534
Gear Ratios (overall) 2nd 7.302
Gear Ratios (overall) 3rd 5.423
Gear Ratios (overall) 4th 4.392
Gear Ratios (overall) 5th 3.741
Gear Ratios (overall) 6th 3.157
CHASSIS
Exhaust Chrome, 2-1-2 dual exhaust with tapered mufflers
Wheels, Front Type 9 Black, 7-spoke Cast Aluminum
Wheels, Rear Type Black, 7-spoke Cast Aluminum
Brakes, Caliper Type 6 piston fixed front with 4-31.75 mm front pistons and 2-25.4 mm linked rear pistons, 31.75mm single piston floating rear
Parking Brake Foot actuated dual parking brake
PERFORMANCE
Engine Torque Testing Method J1349
Engine Torque 2 113.6 ft-lb
Engine Torque (rpm) 3,500
Fuel Economy: Combined City/Hwy 5 42 mpg
ELECTRIC
Lights (as per country regulation), Indicator Lamps 8 High Beam, running lights, front fender running lights, directional lights, battery, neutral, low oil pressure, engine diagnostics, cruise control, speakers, accessory, security system (optional), gear indication, low fuel warning, reverse, park brake, miles to empty display, fog/aux lamp indicator
Gauges Large speedometer and tachometer with wide numbers; large fuel and volt gauges with wide numbers; display features odometer, trip A, trip B, range to empty, and gear indicator; and larger telltale indicators, including new reverse indicator light
1. Recommended 91 octane or higher fuel (R+M)/2.
2. Values shown are nominal. Performance may vary by country and region.
3. Standard and optional fuel systems may vary by country.
4. See motorcycle owner's manual for complete details.
5. Estimated from fuel economy tests on a sample motorcycle from the corresponding family conducted by Harley-Davidson under ideal laboratory conditions. Not all motorcycle models undergo fuel economy testing. Fuel economy and mileage may vary among motorcycle models within a family. Your mileage may vary depending on your personal riding habits, weather conditions, trip length, vehicle condition and vehicle configuration and other conditions. Break-in mileage may vary.
6. Prices listed are the Manufacturer's Suggested Retail Prices. Options such as color are available at additional cost. Prices exclude dealer setup, taxes, title and licensing and are subject to change. Dealer prices may vary.
7. Measurement reflects 180 lb. (81.7 kg) operator weight.
8. North America security system includes immobilizer; outside North America the security system includes immobilizer and siren.
9. Standard and optional wheels may vary by country and region.
