Gear Shift Lever adjustment
wildmongoose
Real Name: Gregg Hood
Years Riding: 1
My Motorcycle: 2009/Honda/Shadow Spirit 750c2
#1 Unread post by wildmongoose » Thu Jan 13, 2011 9:02 am
I would like someone to shed light on how to adjust my gear shift lever on my Honda Spirit 750c2. My boot will hardly fit for shifting. :cowboy:
Re: Gear Shift Lever adjustment
#2 Unread post by totalmotorcycle » Fri Jan 14, 2011 7:47 am
If you are lucky there should be an adjuster on the shifter to bring the angle of it up or down. If not (as it sounds like you have "big feat" like I do (I have the same issues) is to either:
1. Find lower toe height boots
2. Buy a 2nd gear shift pedal and have a friend/shop cut both, weld them together to get a longer one.
2020 Motorcycle Model Guides
2019 Motorcycle Model Guides
#3 Unread post by Johnj » Fri Jan 14, 2011 3:26 pm
You could pull the shifter off the splines and reinstall it in a different position.
#4 Unread post by totalmotorcycle » Fri Jan 14, 2011 4:28 pm
Johnj wrote:You could pull the shifter off the splines and reinstall it in a different position.
Thats a really simple and good idea! Sometimes the simplist answers are the best way to go. :D
