Loose tank question - Total Motorcycle Community Forums
Skip to content
Advanced search
  • Quick links
    • Unanswered topics
    • Active topics
    • Search
  • FAQ
  • Login
  • Register
  • Search
  • Unanswered topics
  • Active topics
Loose tank question
  • Print view
Advanced search
  • 1
  • 2
  • Next
biker_rach
Loose tank question
  • Quote
#1 Post by biker_rach » Tue Jun 06, 2006 10:33 am
My gas tank is really wiggley. Is there an easy way to tighten it up?
Also, my bike has a squeak now :( I don't know what it is. The squeak comes when I go over bumps mostly. Would standing back and hosing the bike with oil help? *sigh*
Thanks for any help!
Rachael
[img]http://csrascootertrash.com/pictures/mybike.jpg[/img]
http://calgary.kijiji.ca/c-cars-vehicles-motorcycles-2006-Suzuki-M50-Boulevard-W0QQAdIdZ28481745
Jamers!
Real Name: James
Re: Loose tank question
  • Quote
#2 Post by Jamers! » Tue Jun 06, 2006 10:43 am
biker_rach wrote: Would standing back and hosing the bike with oil help? *sigh*
Rachael
yup, would probably get rid of any squeek, and any use in your brakes :) as for the tank, checked all the bolts and such? Could be something has come loose, if not then see if you can find where its not fixed in solid as it should be and try to see how that area was once stable.
JWF
ATGATT
Sev wrote:What's a bike?
JWF
Bachstrad37
  • Quote
#3 Post by Bachstrad37 » Tue Jun 06, 2006 10:46 am
I think that bike has 2 clamps. 1 in front near the neck of the frame and another at the rear near the seat. You can remove the seat and might be able to access the clamp bolts from there. The front bolts might need to be tighten too and you may need to remove the plastic engine cover (looks chrome) and get at the front ones.
A co-worker of mine has your exact same bike. I was able to get a gander at it during one of my inspection.
As far as squeeks, they're hard to find. It's not like a car where you can have a passenger listen to it while you drive. My advice is to tighten up various suspension parts first and work your way from there.
And hey, glad to see you back on the boards. :D
2003 VN1500P Kawasaki Mean Streak
2009 Yamaha Nytro FX
MontyCarlo
  • Quote
#4 Post by MontyCarlo » Tue Jun 06, 2006 11:23 am
I think Bachstrad is on track re: the tank, my buddy has the same bike and that setup sounds very familiar, though I wasn't really working on it, more just hanging back, drinking PBR, and saying " yyep " while he tinkered :D
It should be fairly easy to isolate the squeak if you have a helper. get someone to sit on the bike and bounce up and down on the suspension while you move your ear around looking for the squeak. First places to check are the forks and swingarm bushing. Good luck!
"At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul."
CORSCO
  • Quote
#5 Post by CORSCO » Wed Jun 07, 2006 4:16 pm
It looks like you have a VT750. The "loose" tank is normal. I hate to say this but they all do that. There are two large rubber grommets on the frame that the tank slides into. The tank has just enough space to "jiggle." Just double check the mounts.
biker_rach
  • Quote
#6 Post by biker_rach » Sat Jun 10, 2006 10:08 am
Thanks you guys! That's good stuff to know. I did have the seat off and tightened those but they were already super tight (against that rubber thing, that is). But now that I have an idea of where to look I'll dig under that plastic cover to look for more stuff to tighten or play with :)
Thanks a million!
:D
MotoF150
  • Quote
#7 Post by MotoF150 » Sat Jun 10, 2006 12:20 pm
every motorcycle shop sells a bungee strap net in all sorts of colors for around $6.99, you can find one that matches the color of ur tank and use that to secure ur tank
-Holiday
  • Quote
#8 Post by -Holiday » Sat Jun 10, 2006 12:51 pm
MotoF150 wrote:every motorcycle shop sells a bungee strap net in all sorts of colors for around $6.99, you can find one that matches the color of ur tank and use that to secure ur tank
aside from that that would look rediculous, where would you attach the straps?
2000 Suzuki Bandit 1200s
Vespa Rally 200 in pieces
Seetrout
  • Quote
#9 Post by Seetrout » Sat Jun 10, 2006 1:06 pm
moto'll say "Just tie em off to those silver pipes that stick out of those things with all the fins."
Familiarity breeds contempt.
2004 Honda 599
ericeverson
  • Quote
#10 Post by ericeverson » Sat Jun 10, 2006 2:49 pm
Bungee cords are great for holding down gear, the tank on the other hand… no way!
  • Print view
  • 1
  • 2
  • Next
Jump to
  • ↳   Total Motorcycle Talk
  • News, Events and Stories
  • Reviews
  • Rider Cafe'
  • Off Topic!
  • Total Motorcycle General
  • Board index
  • All times are UTC-11:00
  • Delete cookies
  • Contact us
Privacy | Terms
