no lights
no lights
i have a 2003 shadow spirit 750 and i turned my bike off and 5 to 10 min later i started it back up and it had no lights. i checked all the fuses and they were fine. anyone have any ideas on what the problem could be? sure could use the help.
- TechTMW
- Years Riding: 10
I'm assuming you mean "No Headlight" OR what. No signals, brake lights, running light ... ?
If you do mean headlight - You need to check if the High Beam still works. If it does, you just have a blown bulb.
The headlight circuit is very simple. It goes from the battery, to a relay, to the headlight, to a ground point. If the High Beam doesn't work, then it's probable that your relay is shot (Not likely) or your ground point is loose (Check first)
You need to check all of these points for good connections and functionality.
