stalling? help needed
Dirtytoes
ummmm
#11 Unread post by Dirtytoes »
okay, i just opened up the WHOLE bike.....took ALL the fairing off, the gas tank off....but now i can't take the spark plugs off....don't have the "ratchet" or w/e that turns it.....where is the other stuff? air filter...etc
You only live once, abuse it!
and Live Life For Today As Tomorrow May Never Come --BadAss
[img]http://www.MegaShare.com/images/images/553227170/humor00180.gif[/img]
Bikes:
2005 Ninja 500 (sold)
2001 CBR 600 F4i (current stunt/commuter)
#12 Unread post by BuzZz »
What you need most is a service manual for your bike. It will tell you good stuff like what size socket you need for the plugs and where every last bit of stuff is.
Your air filter can be found with a little looking. Find your carbs. Attached to the backside of them will be some sort of boot or connection leading to a plastiv box someplace, probably under the seat. Some place with-in that whole assembly, you will find an air filter.... or at least a place where one is sposed to be. Basically, follow the carbs back...... it can't be all that far away. :wink:
flynrider
#13 Unread post by flynrider »
I'll second that. If you lack a service manual, proper tools and a basic knowledge of where to find things like the air cleaner, I recommend you not take anything else apart until you have a manual. You're just asking for trouble at this point.
Bikin' John
'93 Honda CB750 Nighthawk
Dirtytoes
HELL YA!
#14 Unread post by Dirtytoes »
okay, so i just went to a hardware store...got me a whole set of tools + extentions (the spark plugs are ALL the way in there)
anyway, got them out, went to kolbe cycle sales and bought two new plugs...popped em in there and now it works fine! :mrgreen: ...doesn't stall anymore..
its still a street fighter......but idk, it feels like the bike lost some power.....can it be because of the wind shield? if not, what else can it be? ....the air filter maybe? ...its too dark out right now, will check it out tomorrow....hopefully i'll find it.
P.S. when i opened up the plugs....you know how there is a big piece of plastic that goes around the OTHER end of the plugs? the left one was/looked fine....but the right one, (where i was spraying water from) has some green stuff in it...like algee....can/does that affect performance at all?
Bikes:
#15 Unread post by BuzZz »
That green stuff is corrosion of the copper in the brass connector. It is bad. Clean it off as good as you can.
That 'big piece of plastic that goes around the OTHER end of the plugs' is called the sparkplug boot. You need a service manual so bad, I can taste it. :wink:
kar_the_terrible
#16 Unread post by kar_the_terrible »
BuzZz wrote:That green stuff is corrosion of the copper in the brass connector. It is bad. Clean it off as good as you can.
Hey, at least its not at bad as when I called the vaccum plug on the carb intake boot "that condom thingy" . not to worry he'll learn fast :)
'78 Yamaha XS400
'86 Yamaha Radian
NorthernPete
Years Riding: 11
#17 Unread post by NorthernPete »
here ya go DirtyToes.... I use this, it kinda gives me an idea where everything is on the biek...sorry if I chose the wrong year for your bike.. but you shoudl be able to get the right one..
http://houseofmotorcycles.bikebandit.co ... D11%29.asp
blows up all the parts so you can see where iot all is.
2009 GS500F
Dirtytoes
yaaa!
#18 Unread post by Dirtytoes »
NorthernPete wrote:here ya go DirtyToes.... I use this, it kinda gives me an idea where everything is on the biek...sorry if I chose the wrong year for your bike.. but you shoudl be able to get the right one..
wooooooooooooe....thx a bunch....still lookin to find the air filter tho :roll:
Bikes:
#19 Unread post by BuzZz »
There's a good chance you will have to remove a lid or cover on the airbox before the filter can jump out and bite your azz..... :wink:
Looks like the top cover unscrews and the filter slots down into the airbox from the top from that link to Bike Bandit......
...service manual...... must... get... service manual...
:laughing:
Dirtytoes
#20 Unread post by Dirtytoes »
:laughing:
:roll2: LMAO :roll2:
Bikes:
