Aftermarket exhaust and jetting
- Legendary 300
- Years Riding: 55
- My Motorcycle: 2007 1100 V-Star Silverado
I'm thinking about an aftermarket exhaust for my V-Star and a few questions come to mind. After installing the exhaust, is it best to use one of the recommended jet kits like the stage 1 kit I see in listed in the exhaust section of the catalog, or do you guys take the bike to a dealer who has a dyno and have them jet it? I'm from the old school of jetting where I take the bike out on the open road and run it at a constant speed for about 5 minutes and then read the plugs. If the plugs are white, then it is burning lean, if they are black, it is too rich. I try to find a jet combination that will show a tan color on the plug. As far as the idle circuit goes, if the engine falls back to idle properly and doesn't coast after being blipped, I don't mess with the idle jetting. However, I have never messed with a newer bike that has both side draft and down draft carbs, so I don't know if my methods apply or not. Also does the installation of a tuned aftermarket exhaust actually increase performance, or are they designed to increase noise only. I'm thinking that on bikes like the Star, increased performance may be a myth. XS
1981 Yamaha XS650H
1979 Honda PA 50
1970 Rupp mini
1979 Honda PA 50
1970 Rupp mini
- Legendary 300
- Years Riding: 55
Not to question your answer, but as a rule of thumb, when you open up the exhaust system on an normally aspirated engine such as the V-Star, some jetting is required. I have heard that bikes with EFI may requrie some re-mapping, but not always. Understand why I am cautious, I don't want to fry a piston on a bike with only 2,800 miles on the clock. XS
1981 Yamaha XS650H
1979 Honda PA 50
1970 Rupp mini
1979 Honda PA 50
1970 Rupp mini
- ZooTech
- Years Riding: 18
Of course I understand your concern about frying your bike. But if the intake remains stock (i.e. restrictive) then you're not likely to lean out your A/F ratio by changing your pipes. Your engine will still only be able to swallow the same amount of air as it did before.xsyamahadg wrote:Not to question your answer, but as a rule of thumb, when you open up the exhaust system on an normally aspirated engine such as the V-Star, some jetting is required. I have heard that bikes with EFI may requrie some re-mapping, but not always. Understand why I am cautious, I don't want to fry a piston on a bike with only 2,800 miles on the clock. XS
