1983 V45 crankcase pressure?
Hey guys, need a little help. I have a 1983 Honda V45. My question is that when you check the oil (using dipstick) while running I get a lot of pressure (blow by?) out of dipstick hole, also out of crankcase drain tube. Is this normal?
- flynrider
- Years Riding: 30
If you've got excessive oil coming out of the dipstick and the breather, it could be the result of blow-by. That's combustion gasses getting past the rings and pressurizing the crankcase. Get out the shop manual and a compression tester to see if you've got leakage past the rings.
Some bikes are equipped with a PCV valve. If that gets crudded up, it can also cause your crankcase pressure to rise.
Bikin' John
'93 Honda CB750 Nighthawk
- TechTMW
- Years Riding: 10
Please don't attempt to do anything else to your motorcycle.
Air will naturally pressurize a crankcase because when the pistons move down, they push air down as well. There is usually a vent on the crankcase to prevent this from affecting your case seals (Like the vent/hose from the case to the airbox.)
- Stratus311
You really shouldn't check the oil while running. If you check it while running, the level will change when you shut off the bike to add oil. Alot of your oil is in the top half of the engine when it's running. And yes it is common even on an engine in perfect shape to have some pressure in the crankcase. Hence the need for a PCV system.
[img]http://www.careercoders.com/images/Small-pictures/bike-sig.png[/img]
"Fighting for peace is like screwing for virginity."
“When you step on the brakes your life is in your foot's hands”
-George Carlin
-George Carlin
Thanks everyone for the input.
you need to ride it some before you check compression.you could have a stuck ring that might free up after running a little while.do not check compression with the engine cold.readings on cold engine mean nothing unless a cylinder is completely dead.more about the gas problem later.have to go.check compression with throttle wide open.
dr bob
