WHAT?! Verm said somethign negative about sport bikes?!you'll be tired even before you ride at the track
Tires w/ 3000 miles are no problem. You've never really used most of the tread anyway, and those tires are good for 6000-9000 miles easily. 3000 is just broken in.VermilionX wrote: riding to the track is not a good idea... you'll be tired even before you ride at the track.
actually, it's not as bad... it's only about 100+ miles away.
but the main thing is if something goes bad... then you'll have no way of going home if your bike doesn't run anymore.
as for track prepping the bike, it's not good either... the advice is to track prep the bike the night before so you'll have enough time and not panic and be sure to pass the tech inspection at the tracks.
also, i need to disconnect the light wires... i think that's what the trackday org requires. i'll check it again later.
as for the tires... it's for my peace of mind. i don't wanna use a tire that has maybe 3000 miles (estimate miles i'll have before that trackday)
plus if it doesn't pass inspections, i'll be very pissed at wasting my time and money going there bec my tires didn't pass inspection.
the mods i did(TRE, SET valve, GP shift) are cheap... not even $100. they're very simple mods.Sevulturus wrote:Considering he needs his mechanic to remove his turn signals I think it'd be best if he trailors in the bike.
Maybe instead of spending money on stickers and performance upgrades of "questionable" value you should be saving for a cheap truck to transport your bike if you're so interested in racing.
OR did you just want to LOOK like a racer?
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
Follow us on X / Twitter - Facebook - YouTube - Pinterest - Instagram - News RSS Feed |
