That would be no good on this bike, cause it will spew right onto the batterysharpmagna wrote:Don't fill it too far up the filler neck though or you might have gas spewing out the key hole in your gas tank![]()
As far as I know, CA is the only place that has that STUPID accordian rubber piece that has to be pulled back. Whoever came up with that idea deserves a serious beating.VP wrote:Some service stations such as Exxon's allow you to just tilt the fuel nozzle slightly inside the fuel tank to allow maximum input. Other stations such as Mobil or Cheveron require the nozzle to be fully inserted into the tank...to get by this, use your right hand to hold/guide the nozzle, while using your left hand to pull the accordinon like rubber piece around the nozzle all the way up...this allows the gas to come out of the pump. Keep the tip of the nozzle inside the tank, as once fuel is touching the nozzle, the pump automatically stops.
lot's of tree huggers here in CA... it helps to reduce vapors and protect the environment.isnowbrd wrote: As far as I know, CA is the only place that has that STUPID accordian rubber piece that has to be pulled back. Whoever came up with that idea deserves a serious beating.
I saw those in VT and NH when I went to pick up my bike this past Tuesday. I see them in NJ occasionally too. Vapor recovery nozzles.isnowbrd wrote:As far as I know, CA is the only place that has that STUPID accordian rubber piece that has to be pulled back. Whoever came up with that idea deserves a serious beating.VP wrote:Some service stations such as Exxon's allow you to just tilt the fuel nozzle slightly inside the fuel tank to allow maximum input. Other stations such as Mobil or Cheveron require the nozzle to be fully inserted into the tank...to get by this, use your right hand to hold/guide the nozzle, while using your left hand to pull the accordinon like rubber piece around the nozzle all the way up...this allows the gas to come out of the pump. Keep the tip of the nozzle inside the tank, as once fuel is touching the nozzle, the pump automatically stops.
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
