i see... the canyons i ride to are not that close, it won't be practical time-wise to use the streets instead of the freeway.ZooTech wrote:Yeah, it sounds like you may be thinking a little too much and not enjoying yourself. Fact is, if you do a lot of straight-line riding (i.e. freeway commuting) you're gonna get flat spots. My first rear tire was pretty squared-off by the time I replaced it at 9200 miles, but my second was evenly worn when I replaced it at 5100 since I started taking the back roads to work and started riding places like the Dragon and Triple-Nickel. I don't imagine you'll get much more than 5000 miles out of your tires, so I really wouldn't worry a whole lot about it. It's just part of the cost of ownership.
cool! thanks for the info.dieziege wrote:Verm... hmm.... how do I retain at least a certain appearance of friendly good will when I say this? ... oh well... Verm, if even you wonder whether you are being silly, you are being VERY silly.
A few seconds wobbling back and forth on the freeway every few minutes won't reprofile the tires. If you wanted to quickly reprofile your tires you might do a burnout like the one in that video you posted the other day...but please don't. Tires are designed to have more tread in the center where most of the wear normally happens... and better tires are designed to have a harder compound in the center and a softer compound on the outer portions so you always get better traction (and higher wear) when cornering.... if you were to actually wear down the off-center tread you would just be killing the tire faster for no good effect.
if i buy a race tire... im gonna go w/ medium.DirtyD86 wrote:unless you "pee" golden coins you should ride a harder tire
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
Follow us on X / Twitter - Facebook - YouTube - Pinterest - Instagram - News RSS Feed |
