What is your prefered brand of spark plug?
poppygene
Re: Sparkplugs
#11 Unread post by poppygene »
BDRONAGOLDWING wrote: I have used NGK and ND and another set of Splitfire plugs but I couldn't tell a lot of difference in any of them.
Granted I'm a diehard skeptic, but I think the Splitfire concept is a sales gimmick. :twocents: :mrgreen:
keysman
#12 Unread post by keysman »
I switched my plug from the stock NGK to the projected tip NGK in my bike to help reduce surging at low rpms. It's a common thing to do in the F bikes. It helped out some.
Old & Busted: 2003 BMW F650CS
XJ1100
#13 Unread post by XJ1100 »
Definitely NGK, this is the only brand to be using in japanese. bikes. Although champions seem to do OK in outboard motors, briggs, techumseh, etc.
'82 Yamaha XJ1100J
oldnslo
Real Name: Lamont Cranston
Years Riding: 20
#14 Unread post by oldnslo »
Sticking with owners manual suggestions is probably best. That would be NGK or ND for Japanese bikes, usually. If your outboard calls for Champions, that would be the place to use them. Then when they fail, you could use them for fishing sinkers, their original intended use. Champion hasn't made a good plug since at least the '60's, IMO.
John
"83 XJ900RK
Gadjet
Real Name: Owen Clark
Years Riding: 19
#15 Unread post by Gadjet »
I use NGK in my bike.
I briefly thought about going to Denso Iridiums, but at 5 times the cost of my NGK plugs........you do the math.
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
#16 Unread post by BuzZz »
Splitfire and any other type of muli-electrode plug will do nothing for a street engine that a regular plug won't. Save your money and use conventional plugs.
oldnslo
Years Riding: 20
#17 Unread post by oldnslo »
One of the magazines did a test of the Split-Fire a couple years ago, and concluded they are a total waste of money.
John
"83 XJ900RK
storminsince73
#18 Unread post by storminsince73 »
well, I use the ngk iridiums, i don't run cheap/stock plugs in anything, i also run k&n filters on everything, and mobil 1... with5 bikes and 6 cars, k&n and mobil love me.
Norm
Here, let ME show you "zoom, zoom, zoom"!
honda599
#19 Unread post by honda599 »
NGK all the way.
Fearless
#20 Unread post by Fearless »
G'day All
My manual suggests that I use Bosch plugs for my BMW, however they also say that NGK are accectable.
I use NGK as the one set of Bosch I tried, the top broke on the plug as I was putting it in the socket. That god I did not put it in the engine when it broke.
I use NGK :D all the time and have not had a problem with them.
Fearless
