Un-Lowering a Bike
Un-Lowering a Bike
I recently acquired my VStar Classic 650 and the previous owner has lowered the bike a couple of inches. Im a pretty big guy (6'2" @ 260lbs) and have already scraped the bottom on a couple of awkward speed bumps in my area. I dont *need* to have the bike as low as it is and it seems to be more of an inconvenience than its worth. I'm wondering how much of a chore it is to restore it to factory height. Unfortunatly for me, I dont know what type of modifications were done to get the lowered effect but I was hoping all you smart people might have some ideas and suggestions. Is there more than one way to lower a bike? If so, what can I look for to determine the type of lowering?
Any thoughts and suggestions are welcome.
Did a little research and I can see now that the rear monoshock was relocated approx 1.5 inches forward from its stock mount location.
As illustrated here: http://www.650ccnd.com/julio.htm
So in theory, if I move the shock back to the factory mout location, that should bring my rear end back up right?
Are there any other things I should look for in the rear? Can I adjust the shock at all while im moving it? Also what about the front. I saw another webpage that showed how to cut some spacer inthe fork to drop it a bit. Are there any other common methods for lowering that that I should look for?
- ZooTech
- Years Riding: 18
Sounds about right.BrandonJG wrote:So in theory, if I move the shock back to the factory mout location, that should bring my rear end back up right?
Well, after you move it and get it anchored down again you can increase the preload if it isn't already at its highest setting.BrandonJG wrote:Can I adjust the shock at all while im moving it?
Havent undone the drop yet but noticed that my preload is set at 1. Whats the trick to stiffening that up. The manual's instructions seem to be vastly understated. Says to just use the special wrench & pry bar to turn it but not amount of prying seemed to make any difference for me. What am I missing?
