from 1000 to 750...
CNF2002
#311 Unread post by CNF2002 »
I can't imagine there not being a mechanic who can tune the suspension at the dealer.
Surely this is a common thing. I would imagine there would be a sheet available somewhere that lists the appropriate settings for the weight of a particular rider. As I understand it, it's just a dial that you turn.
2002 Buell Blast 500 /¦\
VermilionX
#312 Unread post by VermilionX »
CNF2002 wrote:I can't imagine there not being a mechanic who can tune the suspension at the dealer.
i'd do it myself if there was a guide like that for my bike.
although i still have to take it to a shop since the rear shocks preload can only be adjusted by a special tool.
TR7
My Motorcycle: 79 xs600
#313 Unread post by TR7 »
check the tool kit?
VermilionX
#314 Unread post by VermilionX »
check the tool kit?
yep... nothing in the tool kit.
the manual specified it that it's not recommended to do it yourself bec it said there's a special tool to adjust.
although if you really wanted to... you can use a screw driver and hammer it. i wouldn't want that though.
CNF2002
#315 Unread post by CNF2002 »
Are you sure its not just a torx or hex screw?
TR7
#316 Unread post by TR7 »
Im surprised, even my GS500 has one in the toolkit. Maybe you should just borrow another riders :laughing: . I really dont feel you need to take it to a shop to adjust the read preload.
VermilionX
#317 Unread post by VermilionX »
TR7 wrote:Im surprised, even my GS500 has one in the toolkit. Maybe you should just borrow another riders :laughing: . I really dont feel you need to take it to a shop to adjust the read preload.
well like i said... i'd do it myself if i knew what setting to use for my weight.
and do you know what kind of tool is needed for it?
here's what it looks like, those 2 silver things directly above the spring...
-Holiday
#318 Unread post by -Holiday »
all the ones ive seen, including mine, look like this:
2000 Suzuki Bandit 1200s
Vespa Rally 200 in pieces
Mintbread
#319 Unread post by Mintbread »
The Crimson Rider® wrote: and do you know what kind of tool is needed for it?
Yeah, a hammer and a big screwdriver.
Up is softer preload and down is harder preload. Simple.
VermilionX
#320 Unread post by VermilionX »
i already knew that but like i said... i don't want to hammer it and i don't know what setting to use.
Locked
