Front brakes Squeak.
Gilfy650a
Location: Northern Kentucky, "Like the rest of KY only better"
#1 Unread post by Gilfy650a »
I was origionally going to post this in General, but decided a maintnence forum would probably be a better place.
My front brakes have been squeaking ever since my lowside last year. I was working on the bike the other day and had a buddy sit on the back of the bike to get the front wheel off the ground, and spun the wheel. It squeaked sure enough, I replaced the front pads last year and did not bleed the brakes afterward.
What do you all suggest to get the brakes to stop squeaking?
Currently Bikeless
SUPER AWESOME VILLAINS FOREVER!!
Its settled Suzuki SV650 as next bike. :D
CentralOzzy
Real Name: AL
Years Riding: 42
#2 Unread post by CentralOzzy »
OK....Assuming that they are not worn out....what you do is remove the pads, take them over to some smooth concrete or perhaps black-top & rub them on the chosen surface in a figure 8 pattern. This will de-glaze them.
Refit & Hey Presto, no more squeaks....at least for a while. :wink:
Gilfy650a
#3 Unread post by Gilfy650a »
Hmm, that would work for a short period of time, but when the pads are on the bike they touch the rotors ever so slightly so its just a matter of time before they glaze up again. :(
Currently Bikeless
CentralOzzy
Real Name: AL
Years Riding: 42
#4 Unread post by CentralOzzy »
Try a different brand of Pad.
See also: viewtopic.php?p=14947#14947
Telesque
#5 Unread post by Telesque »
Maybe you should try feeding them?
And if they still don't shut up, scream at them, slap 'em across the head, and send them to bed.
-'95 Honda VT600CD / 'Shadow VLX Deluxe'
-'84 Ruestman WTF606
"[The four stroke] cycle is basically this -SUCK, SQUEEZE, BURN, and BLOW." -Dan's Motorcycle Repair Guide.
http://www.dansmc.com/MC_repaircourse.htm
Gilfy650a
#6 Unread post by Gilfy650a »
:laughing: :laughing: :laughing:
Currently Bikeless
Randy
Real Name: Randy
My Motorcycle: 2007/Honda/CBR1000
#7 Unread post by Randy »
Mine squeak too, but only when I am backing up, it is weird. They aren't binding, and they still have plenty of meat on them. I chalk it up to weird but not worth getting to upset about it.
Trying is the first step towards failure - Homer Simpson
05 Yamaha VMAX
04 Suzuki SV650
05 Suzuki RMZ450
kathy
#8 Unread post by kathy »
Maybe the reason why it squeked because it needs a little lubrication. if it still squeaks, try providing a new one for your safety. :wink:
#9 Unread post by Sev »
kathy wrote:Maybe the reason why it squeked because it needs a little lubrication. if it still squeaks, try providing a new one for your safety. :wink:
I thought that brakes and specficially brake pads were meant to provide friction... wouldn't lubing them sort of defeat the purpose of having them?
bigswifty
#10 Unread post by bigswifty »
maybe diulectric grease where the pads contact the caliper?
thats how your supposed to install new ones i thinks.
