mysta2 wrote:what kind of paint do you shoot? do you prime after sanding or shoot straight color? are you clearing it?
I missed this earlier. I have sprayed dupont, sherwin williams, ppg (and a few others I can't recall just now.), stand alone colors and clear coats. I have cleared standard basecoats and cleared over gloss color coats -- all the same -- if you know what you are doing.
Not necessary to prime after sanding except for areas where body filler has been applied or there is bare metal. (this all depends on the result you are looking for. Are you seeking a show car type finish or simply something that looks good and is durable enough to last?) If you want show car quality ---- take it to a pro. I shoot a sealer before color coating, if possible and I tint the sealer to approximate the color. By doing that you can save a coat of paint without worry of dark/light areas.
If changing color, I recommend that you sand thoroughly and then prime with a catylized primer. Then you must sand before spraying. (That is if you are looking for the best of jobs)
I recently shot my motorcycle tank (black) with a good quality non-automotive urathane as an experiment. Total cost of paint actually used, about $1.00. So far it seems to be standing up very well. Totally resistant to gas spills as far as I can tell although I always do my best to avoid splashing on the tank.
GarryS ---- "We learn from experience that men never learn anything from experience."
