Call me old fashioned but...
- biff
- My Motorcycle: yeah sure
http://www.ridleymotorcycle.com/html/motorcycles.htm
Check these bikes...they're automatics! I've never seen these before. That's cheating!
Honda, Harley , Kawasaki. Two wheels are two wheels...watch out for your fellow riders.
- tchaftantouri
- Regular
- biff
Ya' got me on that one...I imagine the weight diff has to be significant after adding a fully automatic transition. Accesable or not, I think it takes away from what it means to be a rider. You need to know a few things and if any old body can just hop on o bike and go...welcom to squid vill.
It doesnt shift, it has a CVT transmission. It is is a belt on two cones kind of like this l>=<l and depending on engine speed, the weights that reside in the cones provide more or less centripital force causing the cones to become either further or closer and because of the cone shape and the distance the belt rides determines the gear ratio. It doesnt shift like an automatic does so you really dont have to worry about going around corners nor does it weigh any more than a standard transmission (might be less actually). As for engine brakeing I wouldnt know, but you *shouldnt* have to hold the brake at a light as the belts should completely dissengage at idle. I actually think its a really great system.
- pinger05
- Legendary 300
- Real Name: Dan
- Years Riding: 10
- My Motorcycle: 2005 Yamaha V-Star 650
Exactly what he said. It doesnt jerk while shifting like a car. Insted it keeps you at a steady RPM (decided by the centrifical clutch or comptuer). Check out this article on CVT. http://auto.howstuffworks.com/cvt.htmTR7 wrote:It doesnt shift, it has a CVT transmission. It is is a belt on two cones kind of like this l>=<l and depending on engine speed, the weights that reside in the cones provide more or less centripital force causing the cones to become either further or closer and because of the cone shape and the distance the belt rides determines the gear ratio. It doesnt shift like an automatic does so you really dont have to worry about going around corners nor does it weigh any more than a standard transmission (might be less actually). As for engine brakeing I wouldnt know, but you *shouldnt* have to hold the brake at a light as the belts should completely dissengage at idle. I actually think its a really great system.
2005 Yamaha V-Star 650 Classic
Ural Patrol <Wish list>
All it takes for evil to triumph is good me to do nothing
- Skier
So, how old fashioned are you? Honda made automatic bikes in the 70s.
