Hesitation at idle & steady low speeds
a_alyte
#1 Unread post by a_alyte »
I have a '90 Gixxer 750 & when I hold the throttle at a steady low speed (1st to 3rd gear), the engine hesitates. This hesitation can also be heard at idle. Once I start to reach higher speeds (40+) I experience no hesitation at all. When I twist the throttle past the hesitation spot, the bike accelerates fine. The plugs are 2 months old.
Any ideas?
9000white
#2 Unread post by 9000white »
you need bigger slow jets.
dr bob
flynrider
#3 Unread post by flynrider »
Or the carbs just need cleaning. Low speed hesitation could be gunk in the carbs idle circuit.
Bikin' John
'93 Honda CB750 Nighthawk
