rear tire seem to be losing around 1 psi/day.
VermilionX
#1 Unread post by VermilionX »
should i be worried?
i hope it's not a big deal. i still have plenty of thread left on it.
Lion_Lady
Real Name: Pam
Years Riding: 24
#2 Unread post by Lion_Lady »
There may be a problem with the valve stem, OR you may have another problem. Might be a good idea to have it checked out by a tire place.
That reminds me, I've got to go get a valve stem tool... my front valve stem has "issues."
P
DivideOverflow
#3 Unread post by DivideOverflow »
Most likely the valve stem. On my old bike, my valve stem thingy came lose. Just get the tool and tighten it up. If it still leaks after that, have someone look at it.
2008 BMW K1200S
2003 Z1000 - For Sale
2004 Hyosung GV250 - sold
asiantay
#4 Unread post by asiantay »
Just tighten it up. If you don't have the valve stem tool, you can do it with a very fine pair of pliers. I got an air compressor and I don't mind using it so 1 PSI a day doesn't bother me... but you should get it checked out anyways.
Lenny: Hey George I want a dog.
George: Shut up Lenny, you're too stupid for a dog.
Lenny: At least I'm not an @ssoff.
- Of As and Off
#5 Unread post by Sev »
You shouldn't be losing psi that fast like everyone has said.
And because you seem to keep misspelling it, it's TREAD, not THREAD.
WVUChrome
#6 Unread post by WVUChrome »
Also, I know you are in Cali, but keep an eye on the ambient temperature. Cooler temperature equals lower pressure in your tires. I highly doubt it would be responsible for a psi lost a day, but it may play a factor.
Later,
Chrome...
flynrider
#7 Unread post by flynrider »
I didn't see anyone mention this one : Check carefully for nails. A nail in the tire can cause a very slow leak, such as you describe. If you find one, don't pull it out unless you plan on fixing it then and there.
Bikin' John
'93 Honda CB750 Nighthawk
NorthernPete
Years Riding: 11
#8 Unread post by NorthernPete »
our some soapy water on the tire and around the stem, look for bubbles and youll know if you have a small slow leak. save you the trip to the tire place if its that.
2009 GS500F
qwerty
#9 Unread post by qwerty »
Some aluminum wheels are porous enough to leak slowly. A couple coats of enamel between the beads is a on the tire side of the rim will usually solve the problem. Be sure to rebalance after the tire is replaced.
VermilionX
#10 Unread post by VermilionX »
thanks guys.
i don't see any obvious tire damage.
i'll check the valve stem thingie.
and thanks for the "tread" correction. :wink:
