Good advice if you don't know what you are doing!MAKER wrote:That's what I thought. LOL ... thanks...Lion_Lady wrote:What is recommended in the MSF class is to pull in the clutch and just keep 'tap tap tapping' on the shifter as you slow down, until you realize the shift lever isn't bumping DOWN anymore. Then you should be in FIRST.CORSCO wrote:Do not go from 5th to 1st in one action. Go through the gears one at a time.
MAKER
Gear Sticking on Spirit 750?
