Anybody here un-mount , re-mount your own tires ?
I'm thinking of buying motorcycle tire spoons/levers 'cuz one tire slow leaks along the bead and I want to sand down the rim to get a airtight seal...
but I would never consider doing car tires - just wondering if mc tires are as hard to deal with as car tires ??
or maybe i'll just shoot some fix-a-flat into the tire.
- Legendary
- CNF2002
- Site Supporter - Silver
Google in the video section for changing a sport bike tire. There's a great video that shows you the whole thing step by step.
2002 Buell Blast 500 /¦\
- logitech104
- Legendary 500
Re: Anybody here un-mount , re-mount your own tires ?
good luck cleaning up the huge mess it'll leave on your rim the next time you change your tire.superskip wrote:or maybe i'll just shoot some fix-a-flat into the tire.
- Legendary
The shop I work at has a $10 surcharge if we have to change a tire with slime in it.logitech104 wrote:good luck cleaning up the huge mess it'll leave on your rim the next time you change your tire.
- logitech104
- Legendary 500
.black mariah wrote:The shop I work at has a $10 surcharge if we have to change a tire with slime in it.
thats not too bad..
- Skier
It's not too tough to do, with the right tools and some know-how. Best way to get started is to have someone show you, of course. Failing that, you can try learning from:superskip wrote:I'm thinking of buying motorcycle tire spoons/levers 'cuz one tire slow leaks along the bead and I want to sand down the rim to get a airtight seal...
http://www.clarity.net/~adam/tire-changing.html
http://users.net1plus.com/holbrook/tireeqpt.htm
http://users.net1plus.com/holbrook/tireproc.htm
http://www.totalmotorcycle.com/Motorcycle- ... -tires.htm
Also, I doubt some of that slime will fix a leaking bead, so I wouldn't waste my time on trying.
- Sev
Once you've done it a couple times it's a fairly simple process. However, sanding down a rim to fix a bead seal... that's going to be FREAKING tough.
- Koss
I dont know about MC tires, but car tires are cake.superskip wrote:I'm thinking of buying motorcycle tire spoons/levers 'cuz one tire slow leaks along the bead and I want to sand down the rim to get a airtight seal...
Good luck though! And be careful with that rim... sanding it down and all sounds like quite a job to me. Good luck though!
http://www.livevideo.com/Koss
