Changing Front Fenders?
Aggroton
#1 Unread post by Aggroton »
Ive done pretty much everything to get this bike running myelf while supervised by my friend who knows alot about all kinds of motors. so with that said i just got a new fender i ordered delivered today. i cant imagine something happening that i wouldnt be able to take care of without my friend being right there to make sure i dont mess up too bad. is this the acme of foolishness? or is this as easy as i think it will be?
oh and its an 82 yamaha 550 seca.
thanks fellas.
thats a sweet bike.
Telesque
#2 Unread post by Telesque »
Erm.. If you're doing anything which involves more than just bolts and nuts, it's always good to have someone along. :)
A front fender shouldn't be a big issue, though.
-'95 Honda VT600CD / 'Shadow VLX Deluxe'
-'84 Ruestman WTF606
"[The four stroke] cycle is basically this -SUCK, SQUEEZE, BURN, and BLOW." -Dan's Motorcycle Repair Guide.
http://www.dansmc.com/MC_repaircourse.htm
Itzamna
#3 Unread post by Itzamna »
I just replaced my by myself the other day in 15 min. Yours is probably even easier. I know my '82 Nighthawk was a breeze taking it on and off.
Brian
'03 Suzuki SV1000
Aggroton
#4 Unread post by Aggroton »
sweet i will attempt tonite...hopefully ill have good news and not more questions tommarow.
thats a sweet bike.
Aggroton
#5 Unread post by Aggroton »
ok so i got everything switched over ok...but im afraid there isnt enough clearence...should i redrill the holes so it will sit better...or just widen the holes and tighten them down alot?
http://totalmotorcycle.com/BBS/album_sh ... ic_id=2658
let me know what you think...thats a pic...is that not enough clearence?
thats a sweet bike.
Telesque
#6 Unread post by Telesque »
Aggroton wrote:ok so i got everything switched over ok...but im afraid there isnt enough clearence...should i redrill the holes so it will sit better...or just widen the holes and tighten them down alot?
Well. if this is a show bike, and you never plan on riding it, sure, that's enough clearance. :)
But I doubt that's what you've intended. Because of the distance you'd probably want to raise the fender, redrilling them would probably work better than widening them.
#7 Unread post by BuzZz »
I got questions....
Is that the back of the fender? Looks like it.
If that's the rear, is there a much bigger gap at the front of the fender?
If there is, can you slightly slot the holes you drilled and slide the fender back in it's mount?
And did you armor-all your tires? :shock:
:laughing:
Aggroton
#8 Unread post by Aggroton »
yeah my brother added armor all while i was purple powering the engine...and yeah there is about 2 inches clearnece in the front. gonna try and redrill new holes...or at least 2 new holes.
thats a sweet bike.
Aggroton
#9 Unread post by Aggroton »
yeah we redrilled the holes and everything is sweet now.
thats a sweet bike.
Telesque
#10 Unread post by Telesque »
Aggroton wrote:yeah we redrilled the holes and everything is sweet now.
Well, do we get to see the final product? :D Or is it just really not all the exciting? ;)
