using the front brake results in fork dive which upsets the chassie. not good for cornering. so can the rear but not as severe. braking through a corner is called trail braking and takes practices to be safe but if done correctly can make you much faster.Gilfy650a wrote:I've heard that you should only use the rear when going through a curve,
it seems to work well enough. is there a particular reason for this?
also the most important thing is contact patch and weight transfer. you have a much smaller contact area with your front tire. in dirt bike racing you want to load the front end going into the corner to dig the front tire in to the dirt.
but much different for street riding. due to the limited contact are of the front and loads imposed on it during cornering. so on the street you want to load the rear tire a little with the throttle and take the stress of the smaller contact area off the front tire.
so using the front brake will load the front tire and may over stress the tires means of griping the road!!!
