hello,
my 1986 suzuki gs550l, I had taken it apart to clean the carbs, I thought that the CGI ignition went bad because I got it wet, I went and bought another, (used) but I still have no spark? maybe there is a wire loose? or ? I checked the fuses but they all look good, also at the same time my electric starter stopped working so I had to cross that solenoid thing withy a screw driver? how can I test the CGI inniter? they are expensive? could it be the coils? I dod not take the coils off, only unplugged a lot of wires around the air cleaner and carbs? any wiring diagrams around? or is there a relay or something like that?any help woul be greatly appreciated?
Thanks,
Ron
No spark!
No spark!
nothing really
- BuzZz
- Real Name: Never Used Here
- Years Riding: 47
The problem must be the CGI. Computer Generated Ignition is just pixels in space, not real. Like all them snakes on that plane movie.
But I bet your CDI (capacitor discharge ignition) is fine. If your starter will not work with the switch at the same time you got no spark, I would start by looking at that switch and the wiring associated with it. Or maybe the key switch. It sounds like the system is dumping juice to ground someplace.
It's a place to start anyways...
No Witnesses....
No spark suzuki gs550L
Thanks, yeah kind screwed up CGI, confused there for a minute, I will start tracing the wires down, because I have tried several "CDI's" I know that they were used but they came off a running bike, a friend of mine had the same bike, is there anyway to even test a CDI?, thanks for your help, I am new to a forum site, I really appreciate all the help.
Ron
Ron
nothing really
- BuzZz
- Years Riding: 47
Most bike shops can and will test your cdi box for nothing or a small fee if you take it in to them.
But I doubt that's the problem. If you've had several units on the bike with the same results, the odds are astronomical against all of them being pooched.
A bad ignition switch, damaged and shorting wire, poor connection.... I would almost bet your problem lies in there someplace.
Good Hunting, Bro.
Good Hunting, Bro.
No Witnesses....
- Sev
I gotta agree with what BuzZz says. If you need to jump the solenoid then there's a problem with the primary starting circuit. Look inside the switch first...
And check the charge on your battery.
- Logitech105
Re: No spark!
I could only get the e/es model, but it should give you an idea for the make of your bike nontheless..
ok that is obviously too small so you can pm me your email adress for a huge pic of it.
here is what the wiring harness looks like for your bike 1986 gs550l.
you must be missing something, a fiend-ish hidden wire of the sort. The cgi / cdi uses the frame as the ground, so I has to be bolted on the frame to work, you can't simply plug it in. I think it is your solenoid for some odd reason. oh yeah and use your original cdi.vegasvalley wrote:only unplugged a lot of wires around the air cleaner and carbs
[img]http://i145.photobucket.com/albums/r201/AeroMyst/fn3.gif[/img]
