Hello... Hopefully someone can help me out here.
I recently bought a 1998 Suzuki Bandit 1200S. After getting it home I started having a problem with the charging system. It starts and runs fine for about 5 minutes then starts to miss and break up and eventually quits. If I let it sit for a minute or so it will start right back up and run fine for a couple minutes, then the same problem occurs again. I tried a new voltage regulator, but it is still charging at 15.3 volts at an idle.
If anyone has any suggestions, it would be greatly appreciated!!!
Thanks!!!
Battery Overcharging Problem
- Gummiente
- Years Riding: 38
That sounds more like an ignition problem to me - especially if you can fire up the bike a few minutes later. I'm suspecting a heat related problem with the ignition, most likely in the coils or pickup. Not being familiar with the layout of your bike, I can't give you much more help than that.
It isn't WHAT you ride,
It's THAT you ride
