1/2 ton. Tundra, Silverado, Titan, Ram, and Sierra all have lower maximum towing capacity and payload than F150.Shorts wrote:"fullsize truck" - again, not specific.
Specific enough?
Yes, thanks. Otherwise I've had listed better trucks.jonnythan wrote:[
Specific enough?
This is NINJA (Geoff)! wrote:
PS - Mistake 1, playing with half tons. Get an F-750 dump body if you want some real towing power without going semi.
That's alot of miles. Certainly more than what am-fm says it can go.Jthmeffy wrote:RandyO over at the www.svrider.com board has a '99 SV650 with 137,000 miles on it. Regular maintenance. Vavle guides finally went out.. he's looking to rebuild it.
Actually, for the most part, Ford engines last just as long overall as GM engines do. There actually was a time when Ford engines were considered to be more durable, and it was said because Ford blocks had some nickel content in the blocks, meaning the blocks were made of a stronger alloy.SMITE wrote:BTW lets see your pretend truck put on the milage of my GMC, probably go thru 3 of those ford motors huh?
William wrote:
I'm sure that for almost everyone here, a 1/2 ton truck is plenty. I think it's more of an issue of the male ego at work. I know I certainly don't need to carry more weight than my F150 can carry. It's plenty for me. I guess that I don't have small dick syndrome that I need to try to compensate for...
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
