Throttle hand getting numb?
allawybiker
#1 Unread post by allawybiker »
I have a bike with a V-Twim engine so I am aware that some vibration is in order, but does your throttle hand get numb? Mine does after about 30+ minutes of highway driving, 60+ mph. Is this normal? Does it eventually go away, i.e. do I get used to it? Any good remedies? Should I grab the handle differently?
Thanks
AB
Suzuki Boulevard M50 Black
Mankind must put an end to war, or war will put an end to mankind.
polarelf2003
#2 Unread post by polarelf2003 »
Happens to me too, especially in cold weather. I try to move my wrist around a little every once in a while, stretch it out and get the blood flowing. Anyone else have this problem or are we freaks?
1977 Honda CB550 F
Dennis27
Re: Throttle hand getting numb?
#3 Unread post by Dennis27 »
allawybiker wrote:I have a bike with a V-Twim engine so I am aware that some vibration is in order, but does your throttle hand get numb? Mine does after about 30+ minutes of highway driving, 60+ mph. Is this normal? Does it eventually go away, i.e. do I get used to it? Any good remedies? Should I grab the handle differently?
Thanks
Man my hand gets numb also. Mine can happen any where from 10mins to an hour after riding. Do you always wear gloves? If so a pad in the palm or else where could be cutting off circulation. I believe that is my problem.
allawybiker
#4 Unread post by allawybiker »
Thanks
I do wear gloves but without padding, they are motorcycle leather gloves with cold weather inserts but no protective padding. I was thinking maybe I need something with rubber padding that would absorb the vibration better than my plain ones! :)
BTW, the numbness does not happen at lower speeds. Only highway speeds where the vibration frequency is higher and constant for a longer period of time.
AB
polarelf2003
#5 Unread post by polarelf2003 »
Hmmm. . . .. maybe it's the vibration. I always thought it was the position I hold my hand. Maybe I'll have to pick up some of those gel padded gloves I've been eyeballing for a while and experiment :D
1977 Honda CB550 F
Telesque
#6 Unread post by Telesque »
You might also consider getting a set of grips that have better padding on them as well. :)
-'95 Honda VT600CD / 'Shadow VLX Deluxe'
-'84 Ruestman WTF606
"[The four stroke] cycle is basically this -SUCK, SQUEEZE, BURN, and BLOW." -Dan's Motorcycle Repair Guide.
http://www.dansmc.com/MC_repaircourse.htm
9000white
#7 Unread post by 9000white »
if you can find them Murray Mountain Bike Foam Grips will greatly reduce this problem.i put them on all my rides.
dr bob
XJRJohn
#8 Unread post by XJRJohn »
often seem to get numb hands lately,put it down to old age and bad circulation.got it so bad coming back from peterborough a few week back had to stop and wait till i got feeling back,funny thing is i was right as rain for rest of journey.xjrjohn
biking isnt a matter of life or death,its far more important(bill shankley,well almost)
choukyla
#9 Unread post by choukyla »
I get numb as well, but for me it's because I grip too hard. When I notice it's getting numb I try to relax more. Oh, same as you, as I ride fast I don't notice it but I grip even harder. That's when my hand run out of blood :-)
DustyJacket
#10 Unread post by DustyJacket »
Start using a Throttle Rocker. It helps me.
www.bacainternational.org
