This is what the service manual says to to:
(Is anyone else worried that they can't spell correctly?)
This is the chart for what the resistance should be between the terminals:
This is what the voltmeter showed when I put the BLACK tester on the GREEN terminal and the RED tester on the YELLOW terminal:
But the strange thing is, when I switch the testers around and put the RED tester on the GREEN terminal and the BLACK tester on the YELLOW terminal it shows this:
Shouldn't it show the exact same measurement both ways?? Does this fall into the .5-10 ohms that the manual specifies?
Here are the rest of my results. This one is BLACK tester on the RED/WHITE terminal and RED tester on the YELLOW terminal:
This is with the testers reversed. RED tester on the RED/WHITE terminal and BLACK tester on the YELLOW terminal:
This is RED tester on the RED/WHITE terminal and BLACK tester on the GREEN terminal:
This is with the testers reversed. BLACK tester on the RED/WHITE terminal and RED tester on the GREEN terminal:
Is anyone confused yet?
