I'm getting horrible gas mileage (20-25mpg) on my Kawa zr750
I can only go 45-50 miles before hitting reserve. When I fill up i only have to fill it up 2 gallons. The capacity is 4.5 gallons. I should be hitting reserve w/ about .8 gallons left.
i don't know if the two problems are related though.
I have a slighly dirty air filter that had been soaked in oil but i was able to rinse it out. I have a new filter on the way. Can this cause the problem?
What else should i check?
Horrible gas mileage
- Regular
- Cockney Rebel
- Regular
someone could just as easily remove the fuel line and turn it to PRI.
well.....the above tire inflation didn't seem to help my mileage at all if any.
I think i rode it about 7-8 miles before i pumped up the tires and changed the airfilter.
so afterwards i was abile to put about 15 miles on it. So I decided to head to the gas station to check how much fuel I've used and I've already used a gallon.
I'll keep experimenting and see the level of my gas. Tire pressure should be when the tire is cold right?
- Regular
