Using Seafoam
jonnythan
#11 Unread post by jonnythan »
Jadien wrote:So I picked some Seafoam up and I'm wondering if I should put it in with a full tank of gas or not? I know to put it in with the old oil, but what about gas? Does it make a difference?
Put it in with a full tank of gas and try to use that entire tank.
tim conroy
#12 Unread post by tim conroy »
Its great stuff!! I put it in every other tank and also used the sea foam spray(Deep creep) directly into the fuel line and it helped the idle.My bike runs and performs better than ever!!! :D It is the only additive I will use.
