2003 vtx 1800c motor problems
jhbstyx
#1 Unread post by jhbstyx »
I own a vtx i love but i think i messed it up. I punched out the exhaust pipe with a rebar to make it a little louder stupid me. Now the back cylinder does not fire. I put new plugs in. It has 12,000 miles. I have no spark at the back cylinder but it seems to get warm. I took a compression test on my own.i read 10 psi in the back and30 psi in fronk am i doomed?
#2 Unread post by BuzZz »
10 and 30 psi compression?
If those numbers are right (meaning the tester wasn't leaking) something major is wrong with your engine. Since it runs at all, I suspect your numbers are not accurate.
Punching the muffler out should not have caused this.
I would re-test the compression (you want well over 100 psi, probably 150-160 for your motor) and if thats good, check your spark and your fuel delivery.
#3 Unread post by Sev »
Can you describe the method you used to test the compression?
jonnythan
#4 Unread post by jonnythan »
10 bar would be about right, as that's 145 psi.
But 30?
#5 Unread post by Sev »
Should be closer to 120psi or 130psi...
