'83 Shadow 500 -- no spark
BirdRacer
#1 Unread post by BirdRacer »
Hi guys/gals. As you can tell, my first post here.
I have a '83 Honda Shadow VT500 that has no spark at all to either cylinder. I don't know the history of this bike, it was given to my dad recently after sitting up for a while.
The battery spins the bike over fine, but shows a little weak at 12.1 volts. I have ohmed the pulse generators at the 4-pin connector under the tank. They ohm'd a little low at around 430 (I think, going from memory here). I don't know if this is too much out of range for them to function properly.
I know the spark units are supposedly untestable, but I have popped them apart and I'm not seeing ANY DC voltage coming into either of them on ANY wire with key on, or while cranking. Shouldn't these have some sort of voltage coming to them at some time? If not, how else can they function. Also, don't have any voltage to the coils, but I assume this is because the CDI's aren't sending any. The coils ohm fine, and I have connected them to my race car and spun it over, and they are fine. They throw a nice blue flame from both terminals.
Any ideas where to go from here? I thought the CDI's may be bad, but not sure at this point. They may be just not getting power for some reason.
Any help is greatly appreciated.
1983 Shadow 500
2002 Intruder 1500LC
2000 KX100
1999 KTM 50 Pro Jr.
