what is a turn signal RELAY?
Dirtytoes
#1 Unread post by Dirtytoes »
i'm trying to install new signals...i don't have a turn signal relay.
when i connect them and for example turn the right signal on, it just stays on...it doesn't blink/flash
is that wat the relay does? if not, wat is it?
...and how do i fix this problem?
You only live once, abuse it!
and Live Life For Today As Tomorrow May Never Come --BadAss
[img]http://www.MegaShare.com/images/images/553227170/humor00180.gif[/img]
Bikes:
2005 Ninja 500 (sold)
2001 CBR 600 F4i (current stunt/commuter)
#2 Unread post by Johnj »
http://www.peakmoto.com/servlet/Detail?no=479
There is a link to a turn signal relay. Basically what it does is when you apply 12 volts to the relay it outputs an on, then off, then on causing the turn signal lamp to flash.
Dirtytoes
#3 Unread post by Dirtytoes »
makes sense. thx.
Bikes:
fireguzzi
Real Name: Trevor
#4 Unread post by fireguzzi »
and you don't fix the relays, you just replace them.
Dirtytoes
#5 Unread post by Dirtytoes »
fireguzzi wrote:and you don't fix the relays, you just replace them.
well, i don't have it connected.
but thx, that was another question that i was gonna ask.
btw, how can i tell if a relay is bad? and wat would/could make it go bad?
Bikes:
#6 Unread post by Johnj »
Dirtytoes wrote:btw, how can i tell if a relay is bad? and wat would/could make it go bad?
When the blinkers stop working you check the bulbs, the switch, the wiring, and then the relay. And what can make a relay stop working, well there is an opening in it's coil which could be caused by manufacturing defect, age, excessive vibration, repeated impacts
Dirtytoes
#7 Unread post by Dirtytoes »
cool
installed everything today, including the relay...took about 1.5 hours all went well!
thx all :D :D :D
Bikes:
